How to get out 2 screws in IAC??
Old Jan 25, 2012 | 08:02 AM
Jeremy5's Avatar
3rd Gear
New member here and i just bought an 02 recently. The IAC needs clean or replaced and i have everything apart ready to clean with carb cleaner but i cant get out the 2 screws connected to the iac, i tried wd-40 but thats not working. any suggestions. Thanks,
Jeremy
Old Jan 25, 2012 | 10:06 AM
01tl4tl's Avatar
welcome to the forum
so you removed the intake manifold to clean the egr ports and passages too--correct?
flipped the TB over and got the cover off no prob?
just the retainer clip or screws are causing you trouble?
do a search on here for iacv cleaning --with pics--posted by fsttyms1
he did a good pictorial--not sure if its in the actual diy list (found at top of main thread list for gen2)
there is a tab (iirc) for the rod- it pulls out and clean the slit on its side
clean out cylinder the rod fits into as well
deep creep (seafoam in spray can) is awesome at getting things loose and then cleaning them
reminder- DC on the airplate in TB both sides and edges- lube throttle return springs
and while its apart lube throttle/cruise cables inside their housings
Old Jan 25, 2012 | 10:53 AM
Jeremy5's Avatar
3rd Gear
Thanks 01tl4tl, i found that thread and he said he used penetrating lube to get the screws loose so i'll give that a shot.
Old Jan 25, 2012 | 12:08 PM
Type-ES's Avatar
Those screws were a bitch. ended up having to use vice grips to get one off, and the other I had to drill off the head. Terrible design.
Old Jan 25, 2012 | 05:27 PM
Jeremy5's Avatar
3rd Gear
got them out by using an impact drill. thanks guys.
Old Jan 25, 2012 | 10:33 PM
01tl4tl's Avatar
impact screwdriver? pics?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Froid
Sep 27, 2015 06:16 PM
