NO AC in sunny Florida
Old Jan 25, 2012 | 07:17 AM
cuervo513's Avatar
3rd Gear
My AC just went out yesterday. The fan blows but compressor is not kicking in. It seems to still have pressure. I attached an old bottle of freon to the low side with a gauge attached & it read read @ 60lbs. but since the compressor wont kick in I think the reading is not too accurate. Does anyone know where the plug is located that I can jump to kick in the compressor to test? I also noticed the condenser fan is not running, it is not getting power. I supplied power to the fan and it does work, just not getting power to it. Thank you in advance
Old Jan 25, 2012 | 10:08 AM
01tl4tl's Avatar
that may be why compressor wont come on- fan isnt working and is required for that system
Ck relay for the fan, swap it with another of same color
beyond that--who are the AC gurus?
Old Jan 25, 2012 | 03:16 PM
cuervo513's Avatar
3rd Gear
I just discovered the condensor fan fuse was blown. I swear I checked that one yesterday. What would cause this fuse to go?
Old Jan 25, 2012 | 10:34 PM
01tl4tl's Avatar
short in its wiring. loose wire, bad ground wire
fuses blow to protect from overvolts too
had the charging system tested this winter? parts stores do it for free
Dec 7, 2020 05:39 PM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
07Acuradude
Sep 29, 2015 03:01 PM
LeVeL
Sep 21, 2015 06:57 PM
