How to clean throttle?
It's the Halladay season!
^ You'll need new gaskets if you remove the TB.
Have the car off when you clean it. You can have someone press the gas, but not necessary, just makes it a bit easier. If you're by yourself, just turn the throttle on the side of the TB and it'll open the valve to clean it.
6 spd soon!!!
You can do a seafoam or what I do sometimes is take off the snorkle tube and get some seafoam deep creep and spray the throttle plate and that will clean the throttle body and idle air control valve ( Iac). Run the car while you do it and open the throttle by manually pulling the cable or have someone rev it up. I am a Honda Tech, and at work we do what is called a BG fuel induction clean, same principle using a special chemical and setup to clean. One way we tell if a TB is dirty is you can see a visible black ring on the outside of the throttle plate. you can also open the plate and shine a light inside.
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
