How to change engine mounts
Old Dec 29, 2006 | 02:41 PM
zryde's Avatar
How hard is it to change the Engine Mount at the front and the one on the passenger side? Does anyone have suggestions/instructions?
Old Dec 29, 2006 | 04:42 PM
acutee's Avatar
Here you go with the instructions:
https://acurazine.com/forums/showthread.php?t=150384
Old Dec 29, 2006 | 08:00 PM
2ndgentl's Avatar
2ndgentl
Its pretty easy. But before you change them check which one's need to be changed. My motor was knocking up against the passenger mount bracket when I would barely hit the gas. Because that mount was torn in half, and the one in front of the radiator would lift up about 2 inches when i would hit the gas, so those were the only two i replaced, now my motor from just replacing those two move like it should (barely no movement). But you also have one in front of the firewall and two tranny mounts that should also be checked.
Old Dec 29, 2006 | 09:55 PM
zryde's Avatar
Thanks I appreciate the info
It does appear to be the front & side mounts, like you mentioned
what's the deal with the tube connected to the front mount?
Old Dec 30, 2006 | 02:09 AM
acutee's Avatar
just disconnect the tube when you remove the mount, and don't forget to connect the tube to the new mount. It is hydrolic tube.
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
Aleax
Sep 11, 2015 11:31 AM
