Horn Problem...
Old Mar 15, 2007 | 09:39 PM
yongque's Avatar
Horn Problem...
I checked the everything connectivity, fuse, and I thought that the reel was the problem but when I changed it the horn and cruise control still doesnt work. Please help I just wanted the horn to work. Thank you
Old Mar 30, 2007 | 07:12 PM
horn not working
Anybody else have this problem? My car recently has this problem also. The horn and cruise control doens't work. Any ideas?
Old Oct 20, 2007 | 01:51 AM
same problem here
I have the same problem as you...my horn and cruise control doesn't work. I initially thought it would be the switch on the steering wheel but I've changed that out and still no luck. I am going to take apart my steering wheel tomorrow and take a look at the cable reel.
check out this thread it has good pictures of the bad reel
https://acurazine.com/forums/showthr...highlight=horn
If anyone else has this problem and has fixed it, please chime in. Otherwise no blind guessing.
Thanks,
UWGrad
Old Oct 20, 2007 | 10:55 PM
Rsoetidjo's Avatar
Rich
Check the fuse first.
Check the ground wire for the horn.
Make sure it's grounded
Old Oct 21, 2007 | 09:22 PM
cbptls's Avatar
My horn doesn't seem to work as well. Checked the fuse and that appears to be okay. I have not unassembled the steering wheel, so I don't think the connection should be bad.
I also wanted to see if the horn would work if I hit the Panic button, doesn't work here either.
Just noticed this is in the 2nd Gen Forum, but I could perhaps still learn something here.
Old Dec 3, 2010 | 05:59 PM
mnm27mnm's Avatar
was the problem ever fixed?
blacktsxwagon
Oct 27, 2015 10:12 PM
Kitsune13
Sep 24, 2015 02:25 PM
Smitty
Nov 8, 2004 09:43 PM
