Horn Problem...
Horn Problem...
I checked the everything connectivity, fuse, and I thought that the reel was the problem but when I changed it the horn and cruise control still doesnt work. Please help I just wanted the horn to work. Thank you
same problem here
I have the same problem as you...my horn and cruise control doesn't work. I initially thought it would be the switch on the steering wheel but I've changed that out and still no luck. I am going to take apart my steering wheel tomorrow and take a look at the cable reel.
check out this thread it has good pictures of the bad reel
https://acurazine.com/forums/showthr...highlight=horn
If anyone else has this problem and has fixed it, please chime in. Otherwise no blind guessing.
Thanks,
UWGrad
Thanks,
UWGrad
My horn doesn't seem to work as well. Checked the fuse and that appears to be okay. I have not unassembled the steering wheel, so I don't think the connection should be bad.
I also wanted to see if the horn would work if I hit the Panic button, doesn't work here either.
Just noticed this is in the 2nd Gen Forum, but I could perhaps still learn something here.
