Hood won't close.
Old Jun 30, 2010 | 12:18 AM
UA5_1993's Avatar
Hood won't close.
When I close the hood of my 2003 tl it completely latches but there is a gap between the grill and the hood and the headlights and the hood. i am able to push the hood down a little more but it still seems to pop back up? whats going on>
Old Jun 30, 2010 | 12:26 AM
SLushhYYY's Avatar
Keep It Simple in
lift it higher..and let it drop
Old Jun 30, 2010 | 06:59 AM
fsttyms1's Avatar
you may need to adjust the hood latch lower. Also make sure the rubber hood stops arent keeping it from going lower.
Old Jun 30, 2010 | 10:13 AM
totaledTL's Avatar
Check the stops & adjust if necessary .
Old Jun 30, 2010 | 12:04 PM
UA5_1993's Avatar
Hey thanks for all thanks for all the responses guys, I have already adjusted the stoppers and made sure they were nit interfering and I have already tried slamming the hood down. How would I go about lowering the latch?
Old Jul 18, 2010 | 09:47 PM
ImperialTL's Avatar
I have the same problem...you need to push this lever(it is attached to a spring) down on the hood latch and then let the hood down...should be fine
very common problem on our cars and 6th gen accords
Old Jul 18, 2010 | 10:14 PM
friesm2000's Avatar
B A N N E D
WTF are you talking about, normally it is just misaligned somewhere and needs adjustment
but yeah OP, dropping the hood a little does help getting it latched correctly
bluetl04
Aug 16, 2016 02:49 PM
Bielikb96
Sep 28, 2015 10:45 AM
dirleton
Sep 28, 2015 07:05 AM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
MilanoRedDashR
Sep 27, 2015 10:15 PM
