Hood won't close.
Hood won't close.
When I close the hood of my 2003 tl it completely latches but there is a gap between the grill and the hood and the headlights and the hood. i am able to push the hood down a little more but it still seems to pop back up? whats going on>
you may need to adjust the hood latch lower. Also make sure the rubber hood stops arent keeping it from going lower.
Hey thanks for all thanks for all the responses guys, I have already adjusted the stoppers and made sure they were nit interfering and I have already tried slamming the hood down. How would I go about lowering the latch?
I have the same problem...you need to push this lever(it is attached to a spring) down on the hood latch and then let the hood down...should be fine
very common problem on our cars and 6th gen accords
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
