Hidden tricks
JDTL-S2002 (07-23-2012)
OTSB708 (07-27-2012)
The cupholders behind the shifter come out for easy cleaning! Also, if you touch the accelerator to the floor and back off immediately, it downshifts. The headlights automatically shut off after 15 seconds when you shut the car off and get out then shut the door.
Do they come out in 01 TL?
The new Cup-holder design is for +02 only arent they?
Also dunno if a Trick but you can Make 1st to last longer without having to WOT or ShiftGate.
Just Press Gas about half Pedal (1/2) and it will last until you go full WOT or make the RPM reach about +5K to upshift.
Otherwise at Full WOT it will Redline Only... And normal Gas will shift superquick at 1.5-3K RPM.
IBankMouse
06-13-2020 12:53 PM
ITSJESTER
17
12-06-2018 02:29 AM
STL TL-S
09-23-2015 08:52 PM
