HID headlight replacement problem
I had my HID passenger side light replaced at tire kingdom. However I'm worried if he put it in correctly as the new headlight points too high compared to the driver's side. Does that mean it was put in incorrectly? or is there a way to adjust the light's height? Thank you in advance for any help.
Info: 2003 3.2 TL
Info: 2003 3.2 TL
Doesn't mean it was installed incorrectly. Yes, there is a way to aim it and if it is too high, then I would recommend going back and having them fix/reaim it. While you are there, buy another bulb and have them aim that one too on the left side. HID's should be replaced in pairs. If you were to stand in front of your car with lights on, you would likely notice a color and maybe brightness difference between the two.
tman570
Jun 11, 2019 07:56 AM
