HID ballast uninstall
Ok I did search a number of threads regarding this topic and about 99% complete in taking out the ballast and igniter part of the HID system. My question is that I disconnected the igniter and have unsecured the ballast out of the head light housing but there is a rubber piece in the base of the hole where the ballast wires go to connect to the igniter. My question is how does it come off? I dont want to pull it the wrong way. I have tried pushing and pulling it through. Does the rubber part come off?
Also is there any tips on securely uncliping the headlight cover piece off the headlight housing?
thanks in advance...
Originally Posted by Split_TL
umm.. all you have to do it unclip the ignitor from the bulb, and unscrew the ballast and pull it off..just push the clip down and out to the side and it will unhook.
Originally Posted by Blazin_TL
you can pull that rubber piece out, its just a seal. make sure wen u assemble everything back that you put that piece back or your headlight will condensate
