Help Tl Newbie
Old Aug 8, 2006 | 01:36 AM
pun3.2's Avatar
Help Tl Newbie
just got a 01 tl and the CEL went on and so did the TCS i put it on the scanner and it read a o2 sensor 1 was bad once i fix the o2 will the tcs go away
Old Aug 8, 2006 | 01:45 AM
adamlee05's Avatar
Thread Police Chief
It should. Replace the O2 sensor, reset the ECU buy disconnecting the battery for 5-10 minutes, and turn it back on. Should fix it
Oh yeah. Invest in sentence structure and try periods.
Old Aug 8, 2006 | 01:47 AM
pun3.2's Avatar
thanks
thanks for the info and about your other comment im not in school so i type the way i wanna
Old Aug 8, 2006 | 01:52 AM
adamlee05's Avatar
Thread Police Chief
You're welcome, but it was a joke. And there is a reason why you learn things at school such as typing...its for when you're NOT in school
Old Aug 9, 2006 | 01:40 AM
pun3.2's Avatar
update
so i put a new o2 sensor today and i disconnected the battery CEL AND TCS STILL ON!!!!!
SENSOR 1 should be the one before the cat correct.
Old Aug 9, 2006 | 11:28 AM
fsttyms1's Avatar
Where did you get your sensor from?
Old Aug 10, 2006 | 01:44 AM
pun3.2's Avatar
yo
i had a brand new o2 sensor but it was for my 99GSR same exact thing 4 prong o2 just the cables were to short so i extended them.
is sensor 1 the 1 b4 the cat or on the cat ?
Old Aug 10, 2006 | 01:56 AM
pun3.2's Avatar
1 more thing
when i turn off my car and engage the alarm, if stand next to the car you hear a buzzing/vibrating noise cant figure it out just wondering if nebody else had this problem
Old Aug 10, 2006 | 12:50 PM
PenancE's Avatar
well for the o2 sensor, try using a o2 sensor that the tl can use...how bout a oem sensor.
Old Aug 10, 2006 | 07:15 PM
pun3.2's Avatar
yo
yea imma buy one but didnt think there was a difference 2 blk1 green 1white same as most honda acura o2 sensors but ok
for the noise that im hearing you cant hear it inside the car only when your outside
Old Aug 10, 2006 | 08:07 PM
PenancE's Avatar
r u standing near the front near headlights? they hum when on, duno about being off..
Old Aug 10, 2006 | 10:30 PM
fsttyms1's Avatar
Just because it looks the same and has the same wire output doesnt mean the sensor reads the same values. Id recomend getting one for the TL and not a 4 cyl integra
Old Aug 11, 2006 | 02:33 AM
pun3.2's Avatar
help
its more towards the rear pass. side
Old Aug 14, 2006 | 11:39 AM
pun3.2's Avatar
bump
still need some help on the noise that im hearing
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
DunesCreations
Sep 9, 2015 12:03 PM
n2booz
Sep 28, 2004 05:35 PM
spankin-cl-s
Aug 12, 2001 05:40 PM
