help with rubbing/grinding noise
Old Apr 23, 2011 | 04:56 PM
dc2kid's Avatar
does anyone know what this could be, when the car is rolling and when i brake the passenger side makes this rubbing noise the same noise you get when you have no brake pads rubbing / grinding noise,
i mostly hear it when i brake, i did my brakes a couple of months ago so i dont think its my brake pads.
did anyone have the same issue could it be my wheel bearing its been 2 years since i got the car and i never changed that and i know my axle boot or wtv is ripped but this noise just came recently
Old Apr 23, 2011 | 06:28 PM
01tl4tl's Avatar
if an axle boot is ripped- the grease for the cv bearing leaks out and road grit gets in = goodbye very important bearing
replace the entire axle assembly for that side with NEW unit from NAPA or rockauto--your choice of places
Old Apr 24, 2011 | 08:22 AM
Carbuff's Avatar
Original Owner / Oct 1998
First stop of the AM only, it's just surface rust on the rotors. No worries.
If more often than that, you need to pull the wheels and inspect. You could have a binding pad, slider pin, or caliper which have worn out your new pads.
Make sure you check it out!
Old Apr 24, 2011 | 11:35 AM
01tl4tl's Avatar
good point carbuff!!
calipers do fail and stick partially ON--taking new pads to nothing in short order
Its one reason that changing the brake fluid is so important- especially as our cars age.
old fluid has contaminents which destroy the caliper piston oring- then the cylinder bore, and the caliper piston gets stuck,,,
its too easy to pop the wheels off and find out whats going on
Did you clean and lube the correct areas during brake job?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
