Help replacing rear oxygen sensor 2000 TL
Old Feb 27, 2011 | 03:10 PM
deziner2's Avatar
Received 0141 code which is rear O2 sensor. Under the car, on the passenger side in the middle of the catalytic converter I saw a sensor. I couldn't see any other one. Is that the right one? I'm having a real hard time loosening the sensor. I have sensor tool and socket wrench & I used PB Blaster to no avail. I am afraid I might snap something or break catalytic converter if I try push too hard..Any suggestions?? I don't have much room for leverage under the car..
Old Feb 27, 2011 | 03:21 PM
xtremex626's Avatar
Regional Coordinator (SoCal)
raise the car higher and use jack stands for your safety. use i believe a 22mm wrench. spray some wd40 beforehand and it should loosen.
Old Feb 27, 2011 | 03:30 PM
friesm2000's Avatar
B A N N E D
actually most of them are 7/8" wrenches, but OP said he had the right socket to do it though
but anyways OP, where are you located (trying to see how rusted the sensor might be rusted in there)
Old Feb 27, 2011 | 09:19 PM
deziner2's Avatar
I drive in NYC and Northern NJ. Bolt isn't moving..Need to buy a jack that goes higher..Guess a 17" breakbar would help also..
Old Feb 27, 2011 | 09:42 PM
friesm2000's Avatar
B A N N E D
good luck getting that sucker out
it might be worth it to let a shop replace it (a new bung might actually have to be welded on...)
Old Feb 27, 2011 | 09:56 PM
fsttyms1's Avatar
Drive the car for a while so that the exhaust gets nice and warm, it may aid in getting it out. Apply a lot of force is all you can do.
Old Mar 10, 2011 | 08:54 AM
*Natasha*'s Avatar
7th Gear
Hi!
How many 02 sensors are on a 00 Acura TL?
Old Mar 10, 2011 | 01:19 PM
friesm2000's Avatar
B A N N E D
two, one front and one rear
but i see you are from Poland, are you here in the USA or Canada though....
Old Mar 11, 2011 | 02:46 AM
*Natasha*'s Avatar
7th Gear
Yes. I'm from Poland. I've never been in the USA/Canada. Unfortunately...
Old Mar 11, 2011 | 09:00 AM
*Natasha*'s Avatar
7th Gear
Where is located the bank 1 oxygen sensor? Nearer engine? Part number this 02 sensor 36531-P8E-A11 or 36532-P8C-L21?
Old Mar 11, 2011 | 12:03 PM
friesm2000's Avatar
B A N N E D
only issue with being over seas, the car might have been built to a different spec then the ones here
do you know if it is a USA ( or Canada, which is slightly different though) or a Japan Spec car?
also if a USA spec one, is it a California emissions car, or a 50 state emissions car
that that could potentially make a difference in needed part numbers
but the A11 would be the front o2 sensor, while the L21 is the rear one, both are bank 1 btw, but sensor 1 and sensor 2, to be more specific
edit: if you would like you can also PM your VIN, and i can doable check for you especially if it is a USA spec car, (is the speedo primary in MPH, along with the HVAC controls in Fahrenheit?)
Old Mar 11, 2011 | 08:12 PM
friesm2000's Avatar
B A N N E D
hey can you clear your PM box Natasha
Old Mar 12, 2011 | 02:18 AM
*Natasha*'s Avatar
7th Gear
Hey, try now send me PM.
Old Mar 12, 2011 | 10:34 AM
friesm2000's Avatar
B A N N E D
sent...
Old Apr 6, 2013 | 09:12 AM
dp19812003's Avatar
5th Gear
Replaced Upstream o2 sensor gas mileage not great
I replaced my upstream o2 sensor and its looks like I have lost about 5 miles per gallon on my gas mileage. I was thinking that since I haven't replaced the downstream sensor maybe that is the reason. The downstream sensor isn't bad yet but maybe mixing a new one with a old might be the issue.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
Mike Bertram
Sep 10, 2015 09:27 AM
DS2000TL
Sep 9, 2015 09:26 PM
NSolace
Sep 3, 2015 08:02 PM
