Help with Replacing High Pressure PS Hose
Old Mar 14, 2012 | 11:24 AM
davewlee's Avatar
HI Guys,
I wonder if anyone has any info on replacing the high pressure PS hose on the 2nd gen TL. I have removed the hose connection from the pump and the steering rack and cut the ss tubing to remove the old hose. I need some info on how does one get the new hose to the steering rack since the hose comes preformed and I cannot get this part(preformed with fitting) to go between the space and the steering rack. Do I have to drop the sub frame to replace the hose?
Any help from anyone who have replaced the PS hose would be greatly appreciated.
David
Old Mar 14, 2012 | 02:30 PM
NSXNEXT's Avatar
You're talking about the hard lines correct? Then yes you need to remove part of the subframe.
Old Mar 14, 2012 | 03:52 PM
davewlee's Avatar
Hi NSXNEXT,
Thank you for the insite.. Yes I am talking about the hard line that thread into the rack. I have previously replaced the rear subframe due to corrosion and that was quite a lot of work. I was hoping that someone had a easy way of doing this. I read somewhere that the dealer charged 2 hrs labor to change, so I was figuring that they must use another way , rather than dropping the sub frame....???
Thanks Again
Old Mar 14, 2012 | 05:28 PM
Skirmich's Avatar
Dealer have an Amazing Army of Tools and Hydro Jacks... So 2 Hours with them must be 5 hours with us...
TL-Rocket
Apr 29, 2023 02:33 AM
cycdaniel
Dec 17, 2019 10:58 AM
HeloDown
Sep 8, 2015 06:51 PM
NSolace
Sep 3, 2015 08:02 PM
