help replacing headlight bulb on 2g
here comes the snow!
read the DIY for bulb replacement on the 2g tl but still have a question. How do you remove the tork screw on the plastic housing?
my tork screwdriver bits wont fit all the way down in the star shaped hole because of this lil piece of raised metal in the center of the screw hole. both sides are like that. Almost like a special tork screwdriver is needed. wtf
if you don't have torx #20, then use a pair of pliers to remove it. very easy to remove it, it is just a screw in plastic, then find any screw that fits to replace it. you actually don't have to use one, if you don't want to; it is there for safety, and more likely the cap wont come loose by itself.
