Help, need to know where to fill tranny fluid...
Old Dec 21, 2005 | 09:00 PM
jcbzhnsr's Avatar
I know this is a stupid question, but I just vought my first import, a 2000 3.2 tl, and I have to take it in for the tranny recall in a week, but I want to make sure ther is enough transmission fluid to last me to the end of the week. Can anyone tell me where this fill tube is, so I can top it off? Thank you for you comments and suggestions...
Old Dec 21, 2005 | 09:11 PM
fsttyms1's Avatar
??? You need to make sure there is enough fluid to get you to the end of the week?? Is it leaking or something? There is a Yellow Dipstick on the drivers side (front of tranny) where you check the level (tranny fluid warm, car off)
The filler is a 17mm bolt Standing on the drivers side fender looking at teh engine, Look to the back side of the tube that goes from the air filter box to the throtle body and down.
the part on the pic on the left should say fill plug not drain plug
Old Dec 22, 2005 | 01:04 AM
jcbzhnsr's Avatar
thank you, and no, no leak, but shuddering. Just making sure there was plenty of fluid. As I said before, I am used to pre-86 chevy small blocks and such. Transaxles aren't exactly my specialty, I appreciate the help. I have no owners manual, and am stuck in Bum-f##k Egypt...
Old Dec 22, 2005 | 09:14 AM
fsttyms1's Avatar
If you are showing signs of a shuddering I would also pay attention to the way it shifts (especially from 2-3) Look for any signs of slipping.(like a slipping clutch ) between the shift. If you see any of that id recomend bringing it in asap.
Old Dec 22, 2005 | 09:37 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Mine started shuddering and the dealer replaced it due to "internal failure".
Old Dec 23, 2005 | 10:10 AM
jcbzhnsr's Avatar
that's the plan here. Goes to dealership on Monday for a replacement most likely. I'm sure they will try to BS me for a bit, saying it was something else. When I called Acura dot com, they pretty much said go in and get a new tranny free on us, man... Quite relieving, just drove the thing off the lot, and the next day the shuddering and the exact same slippage you referred to between 2-3 gear. I guess this is an ongoing problem with a lot of Acuras eh?
Pham Alvan
May 18, 2021 06:48 AM
Charles Bennett
Jan 28, 2018 08:53 PM
Pham Alvan
Mar 16, 2016 09:17 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
Skirmich
Oct 1, 2015 12:59 PM
