Help Intake Manifold
Old Nov 25, 2005 | 01:50 PM
joseph_99tl's Avatar
i cleaned my intake manifold.
easy to do.
but now the idles fast...like 2k rpms...and it surges back and forth.
like between 1.5k and 2.5k.
damn.
i put everyting back correctly.
anyone have any ideas?..
Old Nov 25, 2005 | 01:58 PM
sbuswell's Avatar
I need 2 more gears
make sure all bolts are tight on IM and recheck hoses again to make sure you didn't criss-cross any going into IM. did you take TB off when you removed IM? It sounds like a vacuum line problem.
Old Nov 25, 2005 | 02:03 PM
fsttyms1's Avatar
You have a vacum leak. double check that all the gaskets are ok and make sure all the bolts are tight.
Old Nov 25, 2005 | 03:40 PM
yes i took off the throttle body.
reused the gasket.
you think it's the throttle body gasket?.
Old Nov 25, 2005 | 06:24 PM
damn.
i checked everything.
i drove for a little bit.
the TCS light came on.
it started to bog down a little.
i f'ed something up.
but it's not something obvious.
oh snap..i may have to take it the dealer.
but what do i say?.
that it just started running like crap?.
do i tell them i took off the manifold?.
i wonder if i screwed up one the plastic sensors on the throttle body.
very bummed.
over and out.
-joe
Old Nov 25, 2005 | 06:53 PM
PenancE's Avatar
what u mean bog down a little?
i was gonna say adjust ur idler, a flat screw on the TB and u adjust it clockwise/counter i duno, but yea it sounds somethin different.
Old Nov 25, 2005 | 07:07 PM
well...the car hesitated..bogged down..sorry..
it hesitated...it also. revved back and forth...
like vroom vroom vroom..
i am going to get a intake manifold gasket from acura tomrrow.
but i don't think thats the problem.
Old Nov 25, 2005 | 07:10 PM
one more thing.
the EGR hole was clogged as hell.
and the sticky throttle is also gone.
Old Nov 25, 2005 | 09:26 PM
NSXNEXT's Avatar
Sounds like the Idle Air Control valve is f'ed up.
IAC is part #2 in the picture. Might wanna remove and try to clean it out.
Old Nov 25, 2005 | 09:46 PM
oh man.. thx NSXNEXT.
it seems like "idle air control" would be the problem.
the way it's running.
first thing in the morning.
me take apart....again.
do you think that i need to replace the IAC valve?.
i mean..what could of have happened here?.
don't mean to be a n00b..
you think that IAC thing is clogged..broken...
i'll clean it...see what happens..
thx.
Old Nov 25, 2005 | 10:15 PM
NSXNEXT's Avatar
Definitely not a noob, I've just experienced the same symptoms.
It probably just needs to be cleaned. Pull it off (two bolts) and spray the ports with TB cleaner. Use a toothbrush to get it clean. Reinstall and it should be fine.
Old Nov 26, 2005 | 11:36 AM
that was it.
123.00 for a new IAC valve.
it's actually a little motor.
the parts guy said that they sell alot
of them to service shops.
much thanks NSXNEXT....
i woulda have never have figured this out.
i didn't try to clean out the old valve.
i think thats where the trouble started.
spraying the inside of the throttle body.
stuff getting into the port on the inside of throttle body wall.
the car is running great.
i love this forum...
Old Nov 26, 2005 | 06:39 PM
fsttyms1's Avatar
Shouldnt spray into the TB with alot of fluid. It never gets that dirty. If you had to do it again id lightly spray the TB away from the sensor and us a old tooth brush to scrub then spray a little more and wipe out bad stuff
Old Nov 26, 2005 | 07:24 PM
MrAlex's Avatar
99 SSM Tl
Originally Posted by joseph_99tl
that was it.
At this price, buy an used TypeS Tb ..
Old Nov 26, 2005 | 07:32 PM
good point... i am just happy i solved the problem.
Old Nov 26, 2005 | 07:37 PM
well..i over did it.
i should have known.
i sprayed the shit out it.
i dremel buffed the inside of the throttle body and the butterfly edges.
i prolly got shit into that port.
all said and done..it came out great.
reusing the intake manifold gasket seemed to work also!.
i just have to fix the EVAPORATOR CANISTER thing.
WHERE IS THE EVAPORATOR CANISTER?????..
Old Nov 30, 2005 | 03:54 PM
My99acuraTL
If i am not mistaking the evap canister is adjacent to the driver's side back wheel. It is a black box measuing 10x10x4 inches
Old Nov 30, 2005 | 09:35 PM
thanks..
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
jmaxima03
Sep 27, 2015 10:22 AM
