Help! Dropped tiny bolt into cylinder head orifice...
Hello, while working on changing my valve cover gasket, I also went on to adjust the valves. It was going well until I got to cylinder 6. A very small bolt holding my feeler guage together came loose and feel into what I believe is an oil drain hole. The small 1/2 in hole is located in between two exhaust lifters the nut fell into the 3rd hole going from left to right where cylinders 4, 5, 6 are, so right in between exhaust lifters 5 and 6. Im going crazy trying to figure out where that hole leads to. I have left cylinder 6 at top dead center and I have not cranked it with fear I might mess it up internally. Where does the holes lead to!? 😭
Acura TL 2002 base model
Bolt fell into the right hole in the image, I have tried magnets, cameras and vacuum...
You just MIGHT luck out, if you can drain the oil and run a flex magnet thru the pan drain plug hole and root around inside the oil pan and latch on to it (if it IS a magnetic screw) and not have to drop the pan.
curls
1G TSX Problems & Fixes
Feb 3, 2010 11:37 AM
