Help diagnose pulling symptoms
Old Nov 26, 2014 | 01:12 PM
CL-S6SPEED's Avatar
My car is pulling hard left on acceleration at any speed and starts swerving right when I let off. I can steer the car with the gas pedal basically. Alignment is in check. Any ideas?
Old Nov 26, 2014 | 05:57 PM
3.2TLc's Avatar
Tires, rims, loose suspension or steering component ? Maybe a bad rack ?
Old Nov 27, 2014 | 09:59 AM
ErickUa5's Avatar
Mr.Helpful Diagram
Try switching the front left tire to the right side and see if it pulls in the opposite direction, If it does its your tires.
Also tire pressures make sure they are equal, If not equal it can cause pulling.
If none that worked and you checked what 3.2tlc mentioned then its simply a bad alignment, I would take it back to them.
Old Dec 15, 2014 | 08:35 AM
CL-S6SPEED's Avatar
Turned out to be a radial tire pull guys
Old Dec 15, 2014 | 11:34 AM
MarcDavidoff's Avatar
Thanks for the update. Was it driving normal and quietly just cruising? Just pulling hard left on hard acceleration?
SidhuSaaB
May 30, 2020 12:40 AM
08KBP_VA
Oct 22, 2019 01:55 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
us285126
Oct 2, 2015 02:03 PM
thegipper
Sep 28, 2015 01:01 PM
