HELP. Car Wont Start...
Im having a major(I think) problem with my car and I need some help. I've tried searching but I dont know where to look.
Whenever I run my car hard, meaning drive it fast for a while, and i turn it off and go back to start it in 15mins it doesnt start. It sounds like its goin to turn on but it doesnt. Then sometimes it does, but It idles sooo low and it would shut off so i would have to hold the gas as about 2500 rpms for about 2mins or so until it catches itself. Sometimes during this process the engine makes some knocking noises that can be pretty loud. the check engine light would come on sometimes, but then go away. so i never got to run a diagnostic.
Ive changed the pcv valve, and used the spray and cleaned the intake manifold or throttle body(whatever peice the intake it connected to)-lol- sorry dont know too much about motors.lol.. well i used the spray and sprayed n wiped it moving the butterfly to get in there..
Sorry for the long story, but its been happening for more than a month now, but only when i run the car hard. Usually if i do, like say i race someone, and then i get to where im goin I would leave the car on. causei kno if i turn it off and come back its not gonna start. Please Help..... thanks
Well for starters i would still try to have the ecu read for codes. There may be one.
have you cleaned the IAC? also a bad or sticking egr could cause that. I would start out with just checking to see if a clde is traped on the ecu to read?
On the way!
Get the codes read from the computer. Many things could cause what you're describing.
If the check engine light goes on - and then off, it will still leave codes in the computer.
sittinlow...i think i may have the same problem as you. I would run the car hard and turn it off then turn it back on again and i get the same knocking/clanking noise. The TCS light will come on and the engine would run rough for about 20-30 seconds and then go away. Anyway..since your getting your codes read today..let me know if anything shows up.
BTW..how many miles do you have on your car?...i have about 86k on it..it cant be the engine going bad right?
i had same problem with tcs light and engine light happened after a hard run 1 of your coils is getting to hot. replace the coil it will fix it. 1 bad coil made all 6 cylinders misfire go figure.
![what](https://acurazine.com/forums/images/smilies/what.gif)
this is what you do you erase the codes wait for them to come back may take about 15 min or so. the first code to show up is likely the cylinder coil that is bad. my coil shorted the rest of the system out thats why my car ran so crapie. our tls have coil on plug which means each cylinder has its own ignition coil. if you can not check the computer like i can then buy a coil like 65.00 and then switch it in the cylinders that are misfiring one by one to solve the problem. any more questionns my email is jabyrnes1285@yahoo.com i check this more regularly.
nsl752
14
12-06-2016 07:32 AM
bearingman07936
01-07-2016 03:22 PM
