Heater problem
Old Nov 30, 2008 | 09:13 PM
deep's Avatar
9th Gear
Unhappy Heater problem
Hi. I have to maintain my wife's 03 TL. The heater works off and on. Sometimes only cold is blowing. Then if I go over a big bump the heat starts working. Then at any time the cold air can start, no matter what the thermostat is at.
I took it to Acura and they worked on it for an hour and could not figure it out. They said it may take them 4hours to figure it out at $100/hr.
Any suggestions would be appreciated. [P.S. I am not a handy guy].
Old Nov 30, 2008 | 10:07 PM
totaledTL's Avatar
Search around on here for some things to check. For instance: https://acurazine.com/forums/showthr...6#post10221386
Old Dec 4, 2008 | 05:47 PM
gold2003tl (90)'s Avatar
2003 TL-p
could be a lose wire if it works when you go over a big bump. check that thread posted above me.
Old Dec 7, 2008 | 03:39 PM
deep's Avatar
9th Gear
Thanks. The site is useful but did not fix my problem.
I will have to take it to the dealer and bite the bullit. It is better than my wife complaing about the car [w/o words]
Old Dec 7, 2008 | 09:34 PM
totaledTL's Avatar
What did you do so far to troubleshoot?
Old Dec 16, 2008 | 03:56 PM
Zenica's Avatar
I have this same issue.
1999 TL, heat worked yesterday, today---no heat. Just cold air.
A/C compressor kicks in if "AUTO" is selected but no heat regardless
of the temp displayed on the digital readout. Engine does get to normal
operating temp.
I am going to continue searching here but ideas are appreciated.
Old Dec 16, 2008 | 04:22 PM
Zenica's Avatar
Well, I found the problem.
The heat exchange valve cable, or what ever the Acura designation is for the
cable controlling coolant through the heater core.
I will lube the cable and see how long it lasts.
Old Dec 16, 2008 | 08:40 PM
totaledTL's Avatar
So it was hung up/frozen, or ?
Biggie_B
May 27, 2025 05:51 PM
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
07Acuradude
Sep 29, 2015 03:01 PM
