heated seats
thread was called: Fixed Seat Heater for $3 bucks- probably in gen2 prob and fixes section
Under the leather seat cover is what looks like a mattress heating pad- with the wires running thru it- you know the old school kind- and they still sell today.
A small version of that is in the lumbar and posterier sections of the driver seat.
Passenger only gets butt no low back due to airbag constraints
Often a single wire suffers a break, right about where a mans wallet might exert extra pressure on it, no doubt thats why they put a few wallet sized storage spots in the TL
You cut the burned- literally-burned- wire segment of say 6 inches length and remove.
Using inline wire connectors and a replacement piece of the PROPER- same sized wire, not speaker wire, not whatever you found in the driveway from last year.... the same size-grade of wire, and splice in the new segment
Use heat shring tubing or electrical tape to protect the repair- test- recover seat- install seat in car- did I mention the seat comes out... so the covers clips are removed with ease- disconnect battery first!!! airbags!!!
wham bam thank you ma'am
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-heated-seat-successed-cost-only-%243-607220/
go to google and type in "acurazine tl fixed heated seats"
I wouldn't use any connectors, i. e. butt splices, wire nuts, etc. but solder and shrink wrap. More reliable, you don't want to have to open it up again because a connector fails.
I recently fixed my heated seat with the instructions off this site. Great instruction and illustrations. With two of us, we took out the driver seat, replaced the connecting wires on both sides of the seat pad and reinstalled in about two hours.
Like others have said, hog ring pliers are worth their weight in gold.
Thanks all for the great advise.
It was a good practice to do it twice, though. I didn't use enough solder first time around and it failed.
No, just in general. Been my experience that connectors are more prone to failure than a good solder joint. Flux helps in making a good solder joint.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
