Heated Seat Problems
I'm new to this site and I have a 2000 TL...I think the driver's heated seat is out and only part of the passenger one seems to work....can someone tell me how the heated seats work or what the problem could possibly be? Anything at all would help. Thanks!!!!!!
There is a thread titled fixed heated seats for $3
The pass seat only heats the butt because of side airbag
Driver side heats lumbar and butt
The wires that run the sysytem- much like an electric blanket
get broken and can be cut, sliced in new wire, apply heat shrink tubing
and put it all back together.
Its a bit if a job and you have to remove the seat and the seat cover
to do it, but that is the fix.
Or buy complete $$$ heater unit from dealer
If nothing works on the seat its probably the switch
To use the seat heat- put on High for a few minutes until you really feel it, then turn to low- where a thermostat will turn it on and off as needed to stay warm.
On high it runs full blast full time- and burns out the wires
Just thought I would tell you that I bought the extended warrenty (100,000 miles) when I bought my 2003 TL-S. Well, my driver seat back stopped working, so they replaced the seat heater for free under the warrenty.
And while they were at it, they told me that the passenger one needed replacing too - so I got new heaters at 93,000 miles...awesome !!! The warrenty just paid for itself...
^^^ oh okay
I thought the button did not stay down...cuz i had the same problem w/ the buttons not staying in place
could be the element on the bottom of the seat? I think you should look at the write up where the guy fixed the heated seats but I personally do not feel comfortable taking the seats out and ripping the leather off....but to each their own
The thread -fixed heated seats for $3- will help you understand how the heater works. It looks much like an electric blanket you would put on a bed.
The passenger side ONLY has butt heat due to side airbag sysytem
Driver gets Butt and Low Back- lumbar
Turn on High for a few minutes to warm up then turn to low
which has a thermostat and will turn heat on and off to keep seat warm
Use of high for long periods will cause it to reach a temp overlimit switch and turn off until it cools. Also places heavy drain on battery to run High while idling for long periods-per book
rockyboy
Aug 4, 2024 10:35 AM
billmcd
ILX
Oct 17, 2016 03:33 PM
rockyboy
Jan 25, 2016 06:00 PM
