heated seat problem
wires are burnt most likely.. check the fuse first, but otherwise, you have to resolder new wires or just replace the pads (which won't really fix the problem in the long run cause the wires are just too small for the current passing through them and will burn out again)
Its unusual to lose both parts of the driver heat- normally the seat pan/butt portion fails
Check for power to the seat before digging into it.
the heater element is similar to an electric blanket for the bed. It has wires running thru it, and right where a wallet would apply extra pressure, it breaks 1 wire.
Not worth the $$$ cost for new heater skin, so you fix it instead.
2 things to make it work better:
Store wallet in center console
Run on HIGH for a few minutes to warm seat up, then LOW the rest of the time
See owner book for details- that keeps the wire temps low and allows the system to operate, then rest---operate-rest
If the element is burnt in more than one place like mine was you can get replcmt. elements at http://www.heatedseatkits.com/ for much less & they're a better design.
+1 on that site. I got a kit for my wifes odyssey from them, and it works nicely.
Ive got the same problem with my drivers seat-no heat on the back or the butt..Im just not looking forward to taking my leather seat apart..
My car had this problem also when I bought it; it wasn't disclosed on the window sticker that it didn't work but I pointed out when I bought it that it didn't work.
I am wondering if there would be any way of making the dealer fix it because it wasn't disclosed?
nope, u had to have told them before u bought the car. no the dealership will say that it broke while it was in your possession and if u dont have warranty they wont help u out.
I told the sales guy after my test drive and he said that he wouldn't be able to work the price down as much if they have to fix that.
I also bought an extended warranty with the car but I don't know if it will cover the heated seat problem, I looked in the paperwork for it and it doesn't mention anyhwere anything about a heated seat!
Ok, thanks
I am capable of doing this myself but I have fixed so many different cars for so long I am sick of turning wrenches!
I bought the TL and the additional warranty so I wouldn't have to turn any wrenches.....I guess that idea backfired. But I built my engine for my mr2 and got that all done so if all goes well no more wrench turning there!
yea my drivers side butt is not working at all, ill have to get around to fixing that. it been out for over a year.
wasn't there a recall a few years ago. i am not sure. it sucks only getting a hot back .
how much does the dealer charge for fixing that?
An H3 kit. Used the seat back element & kept the other element in case it craps out. The butt element has the thermost. in it as the OEM one does. They sell elements only for $60 ea. If you go that route better specify which one you need.
I saw this on another forum. Nice step by step pics.
http://joshsworld.com/cars/acura-tl-seat-heater-fix/
:( Harminder Is Lost In
Didnt want to start a new thread so decided i should post here, My driver side seat does not heat up. Back or bottom. Switch lights up and all. Pass side works great. I pulled out the seat and everything seemed good. Any ideas?
have you removed the leather cover for the seat and inspected the wire mat = that is the heater pad
the butt section usually breaks a wire, near where a wallet would make extra pressure on it
upper section--have to look for the burnt wire section, not as common
did you look in the thread= Heated Seat Fixed for $3 it has all you need
start at the end and read forward as needed,,its like the trans thread,,,many years of info
I've read that thread over and was looking for that but the wire may was good. Yes I did remove the battery cables. I checked the fuse also and that was good. It's only the driver seat and both back and butt part do not work. It worked perfect last winter. Never needed them in summer but last week I hit the switch and it didn't heat up :/
Sorry, that's not good enough. You must verify continuity w/ an ohm meter if you really want to test them. There could be an open somewhere that is not visually evident. And if they aren't open they still will not work if there's no power reaching them.
rockyboy
Aug 4, 2024 10:35 AM
billmcd
ILX
Oct 17, 2016 03:33 PM
rockyboy
Jan 25, 2016 06:00 PM
