heated seat
Old Oct 21, 2008 | 10:28 PM
david-s's Avatar
heated seat
I noticed my heated seat, i prefer calling them butt warmers stopped working the other day. I brough new fuses and now the passenger side works but not the driver which is going pretty necessary when winter comes. Where can i get a new motor, and how much will it be?
Old Oct 22, 2008 | 01:42 AM
01tl4tl's Avatar
the driver side gets butt and low back- the passenger gets butt only- side airbag sensor issues
often driver side loses butt section when wire segment breaks in heater
right about where a wallet puts extra pressure on it
Its like an electric blanket with wires running thru fabric
requires removal of seat and leather cover- a piece of wire- some solder- and Bobs your uncle!
See gen2 thread- been discussed recently/last 2 weeks- search for Heated Seat
real thread title is: heated seat fixed $3 successed
Old Oct 22, 2008 | 01:46 AM
01tl4tl's Avatar
note- you cant run them on high all the time- that cause it to hit a temp over-limit switch and turns off until it cools down- then comes back on.
Not very good on system- its for warming the seats 5 minutes
then go to low- which has a sensor to keep seat warm by turning on and off on medium heat as needed
running both on high at idle is too much load for the battery/alt
Old Oct 22, 2008 | 01:47 AM
01tl4tl's Avatar
the dealer would replace the entire heater cover- $750
Old Oct 23, 2008 | 04:24 PM
TLer trash's Avatar
It's not as bad as you might think.....about 8 amps total for both seats on high.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
