Headlights not back on after highbeam
Old Jan 6, 2013 | 04:44 PM
FuriousSam's Avatar
Hi all,
Recently I noticed that after I flash my highbeam, my driver side headlight doesn't come back on. It does turn on however if I were to turn the light switch off and then back on. Do you think some connector is loose or it's time to replace bulbs?
Thanks,
-- Sam
Old Jan 7, 2013 | 07:36 AM
3.2TLc's Avatar
Hey FuriousSam, after "flashing" the highbeams, I'm assuming that you mean that the lowbeam isn't coming on your driver's side ?
Have someone else switch it on and off while you observe what's happening. It's easy enough to check the connector and HID unit for moisture or corrosion. Then try a known good bulb, if all appears to be ok.
Old Jan 10, 2013 | 01:06 AM
FuriousSam's Avatar
Hi 3.2TLc,
Yes the lowbean doesn't come back on after I flash highbeam. Where should I be looking at on the headlight casing to see if there's a bad connection?
Thanks,
-- Sam
Old Jan 10, 2013 | 07:18 AM
3.2TLc's Avatar
Behind the headlamp assembly....where all the electrical wiring connectors and components are located.
Not much room to work, check some other posts and the DIY's for tips on the headlamps.
Could possibly be a bad stalk switch ?
TLrascal
Aug 3, 2018 11:00 PM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
Phambam12
Sep 6, 2015 06:57 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
