Headlights and extra light won't turn on
Old Apr 30, 2011 | 09:40 PM
tq2k3.2tl's Avatar
6th Gear
Hi all,
Could someone tell why my headlights and two extra front orange lights (not signal lights) won't turn on even if I turn the switch?
I took off my dash board completely and replaced my OEM HU. After I put everything back, I cannot see my headlights when I turn it on. Same thing with the front orange light near the ground. Although, my high beam is working fine.
2003 Acura 3.2TL
Thanks,
Old Apr 30, 2011 | 10:54 PM
my.daily'tl''s Avatar
Always Working In
Always check last work if evreything was fine prior to that. Check your combination switch.
Old Apr 30, 2011 | 10:57 PM
Karanx7's Avatar
Unregistered Member
If the headlights are not working, it might be an electrical issue. The yellow part is just a reflector, so it shouldn't light up anyways. The actual signal lights are in a white housing (you'll spot the yellow bulb).
Check connections for the headlights. Are your turn signals working OK?
Old May 1, 2011 | 02:44 AM
01tl4tl's Avatar
was the battery disconnected before working on the dash?
ck the fuses and relays for the headlights
Old May 1, 2011 | 02:45 AM
01tl4tl's Avatar
do you get dash lights?
Old May 1, 2011 | 08:04 AM
tq2k3.2tl's Avatar
6th Gear
Thank you for replying.
My signal lights work just fine. Same with others (backup, brake, dash, so on...)
Yes, I disconnected the battery before doing electrical replacement to the car. Could you tell me where I can locate this fuse?
Old May 1, 2011 | 10:48 AM
01tl4tl's Avatar
disconnecting the battery protected the fuses..
there are 2 fuse boxes inside car, and more-- plus relay boxes under hood
go back and find the loose (not actually tight together-just looks ok) or totally unplugged connector to restore power to your lights
thats my best guess
Old May 1, 2011 | 08:06 PM
tq2k3.2tl's Avatar
6th Gear
I checked all the fuses in the boxes but they're all good.
http://www.flickr.com/photos/6241238...n/photostream/
and the light button is not working.
Old May 1, 2011 | 08:17 PM
Edward'TLS's Avatar
6G TLX-S
If the green fog light indicator not coming on, it can also be caused by the little green bulb inside the switch being burnt out.
Old May 2, 2011 | 06:17 PM
tq2k3.2tl's Avatar
6th Gear
I am pretty sure I missed something either that or I damaged one of the wire and it not letting turn on the headlight. I would be nice if I can find some sort of headlight wire diagram so I can backtrack what I have opened.
mada51589
Jan 9, 2025 04:40 PM
handsom-hustla
Nov 13, 2015 05:04 PM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
