headlights
Old Sep 22, 2012 | 04:04 PM
mstaj10's Avatar
headlights
Somebody tell me how to change these dam headlights...ill be damned if i keep paying 200$ for this sh!t!
Old Sep 22, 2012 | 06:15 PM
3.2TLc's Avatar
Hey Mstaj10, many threads have previously explained replacing the headlights and even the entire HID ballast/igniter factory set-up with an aftermarket version. Also, check out the "DIY" for detailed info concerning the headlights.
Old Sep 22, 2012 | 06:31 PM
2Feisty4you's Avatar
Did u check for a video on youtube, thats how i learn how to do my stuff.
Old Sep 22, 2012 | 10:45 PM
01tl4tl's Avatar
2F get familiar to our DIY section,,most info blows away tube = as we are really into our cars, and there are thousands of us contributing experience, tips, probs etc!
MS= what is your problem exactly?,,off color at start= bulb death from age
or one works sometimes and not others, swaps sides that work, go off while driving etc?
MOISTURE inside housing lens?
need kit to replace waterlogged electronics
59 bucks at www.hidextra.com hooks you up with new everything in one `kit` to make lights work better than new!!
suggest 5000k color,,stock was 4300
if it needs the kit, pull nose off the car and remove headlight assemblies/housing to work on the bench
even for bulbs only- I think its easier to do that- than remove several other parts behind lights to access-- then work blind with that pita clip on bulb
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
