Headlight works half the time?
Old Mar 21, 2016 | 11:38 PM
Dejan13's Avatar
My 00TL driver side headlight(hid light) works on and off. Day light and long beams work perfectly. The car is in really good condition! So my light sometimes goes off or on for no reason. Sometimes i turn on my car, flick the lights on and both work for 5 sec then the driver side goes out, or the opposite happens too. If both are on and i close the hood the driver light goes off. I hope its not a big problem. Any hints/tips on what i should do?
Old Mar 22, 2016 | 03:49 PM
SuperGreg's Avatar
How old is the car, and have you ever changed the lights before? Your lights may be going out. Could be the ballast but if the bulbs are very old I would start there. If it was only one side having issues you could swap the bulbs and see if the issue moves to the other side.
If the color temp of the lights are changing (more purplish) they are definitely going bad.
Old Mar 22, 2016 | 04:47 PM
Dejan13's Avatar
Its only the one side, its a 00 TL. I dont think lights have ever een changed. They are never purpllish but is it normal for them to be blue then turn to a more white after a minute or so? I think my best bet is to swap the bulbs then go from there!
Old Mar 24, 2016 | 06:50 PM
SuperGreg's Avatar
Oh OK I misread your post. Yeah you can swap them, it's kind of a pain because you have to take the bumper off. But at least you'll know. Have you had the car since new (i.e. could the previous owner have changed the lights)? If they are original then it's almost a sure bet they are going bad.
And yes, it's normal to look different/dimmer while warming up.
Good luck!
Old Mar 24, 2016 | 08:59 PM
01acls's Avatar
Before you do anything swap the relays first.
Old Mar 26, 2016 | 01:55 AM
Dejan13's Avatar
[QUOTE=SuperGreg;15711694]Oh OK I misread your post. Yeah you can swap them, it's kind of a pain because you have to take the bumper off. But at least you'll know. Have you had the car since new (i.e. could the previous owner have changed the lights)? If they are original then it's almost a sure bet they are going bad.
Why will i have to take the bumper off? I once tried getting to the light and did(taking out battery and air filter intake) but i didnt have the special key for the hid cover! Where does the bumper come into play? I see the passenger side is easirr to get too!
Im the second owner, the car only had 108000 kilometers when i bought it 5 months ago!
Old Mar 26, 2016 | 01:56 AM
Dejan13's Avatar
Heres a picture! Car has always been in garage and rust proofed for 10years!
Old Mar 30, 2016 | 02:43 PM
SuperGreg's Avatar
Looks good! Were you able to swap the lights?
Old Mar 31, 2016 | 01:19 AM
Dejan13's Avatar
Not yet! Waiting for better weather! Still works half the time, usally is off at start but turns on randomly later.
Old Aug 1, 2016 | 06:22 PM
Homestead12's Avatar
I had a headlight issue and it took me weeks of reading forums online to figure it out. Get a cheap multi-meter and test the continuity of the wiring to your headlights first. My guess is that the ballast needs to be replaced due to water damage.
Old Oct 20, 2016 | 03:06 AM
Dejan13's Avatar
After getting a ballast from the junkyard and putting it in it still didnt work but after swaping the fuses i figured out it was a bad fuse! I dont get how a bad fuse would cuz the light to work half the time or flicker, anyways lights worked all day today!
