Headlight condensation
Old Sep 2, 2005 | 03:13 PM
nort828's Avatar
4th Gear
2002 Tl. Pretty fair amount of condensation clouding the inside of the front headlights. Is this a sealed unit, as in non cleanable, too bad buy new replacments, or can they be removed and cleaned and reinstalled?
thanks again for the help
norton
Old Sep 2, 2005 | 03:20 PM
nort828's Avatar
4th Gear
sorry forgot to add that if the outer plastic lens cover can be removed enabling one to clean the inside, how do you go about it? How do you remove them?
thank you
Norton
Old Sep 5, 2005 | 02:10 PM
moahdriven's Avatar
i
2 DIY's for u...
http://www.acurainspired.com/forums/...?showtopic=572
http://www.abunchofcars.com/diy_page...t_clearing.htm
its not too bad, u just have to be paaattiiient, and it would help to have a friend assist u in taking apart the headlight...did u buy ur car used? if u did im assuming the person who owned it b4 u didnt seal the headlight too well after clearing them.
Old Sep 9, 2005 | 04:35 PM
acutee's Avatar
If the car is still under warranty, it is covered.
Old Sep 10, 2005 | 08:45 AM
Dare_IL's Avatar
Need a WHAmbulance
If your headlights have never been opened and it is fogging sounds like water may have collected in your ballast.
It sits directly under your headlight housing. There is a foam seal that is suppose to keep water that is sprayed up from the bottom from getting in the ballast. But if that seal is a little off it could allow water to enter.
The ballast can take a little water it if is dried out before too long, otherwise it will rust some of the connections in there and possible short it out.
They are about $195 to replace from and OEM dealer about 230 from an Acura dealer so they are not cheap to replace, and that doesn't include labor.
Old Sep 10, 2005 | 04:29 PM
2001andahalf's Avatar
i removed the windshield washing fluid holder, took out one of the bulbs to allow air to get in, turned on my lights and let my car sit in direct sunlight...the water evaporated and left via the hole where the bulb should have been.
Old Sep 11, 2005 | 07:43 AM
Dare_IL's Avatar
Need a WHAmbulance
Quicker just to remove both both bulbs and use a blow dryer to get rid of the condensation.
Make sure there isn't water sitting in the ballast though.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
