Headlight Bulbs
TeAm InSpIrE
Headlight Bulbs
just wondering if ne body knows how to replace the headlight bulbs on a 2000 acura 3.2 t? or knows a place in the toronto,ontario area... because acura dealership is asking 95 dollars per headlight.
Here's a link with some installation tips that I posted:
https://acurazine.com/forums/ramblings-12/two-my-favorite-tv-shows-now-158008/
If you search the forum, there are other posts with more detail.
You'll want D2R bulbs. 4300K is recommended for putting the maximum amount of light on the road.
Does the $95 cost per headlight include the bulb or is that just the labor?
(The bulbs are typically very expensive through a dealer.)
Bob
Bob
The dealers charge up to $135 per bulb!!! just for the bulb!!!!!
They are xenon so that makes them expensive- imported from Pluto or somewhere
For replacement Phillips 4300- see ebay- make sure NEW- not used but good- those are dicey
or see vendor Excelerate- he has the badazzz Kaixen brand bulbs- 6000 with color near OE and better output
you really do get what you pay for in lights and brakes~
TeAm InSpIrE
https://acurazine.com/forums/showthread.php?t=158008
Bob
Bob
Originally Posted by AcuraVibes
no its just the labour
Bob
If you have a few basic tools you can change the bulbs yourself- thats carzy to pay an hour labor to the dealer
And you should replace bulbs in pairs so the light output is even- they change with time
Side note- it takes about 100 hours of use for the color to change and stabilize on new bulbs
u need a security torx bit (with the hole in it, t20) and a 10mm
it takes all of 5 mins to change both bulbs. remove the locking screw, unplug the ballast plug, twist the cap, remove bulb. u need the 10mm for the passenger side to take out 1 bolt so u can move hte washer fluid tank neck out of the way
and btw i just bought some 12k bulbs off ebay for about $35
TeAm InSpIrE
well i got my hands on a torx bit t20 ty everybody for the tip... i will be installing my headlights bulbs tomorrow...hopefully it is easy to install i will tell u guys how it went... thanks again everybody...
