Headlight Bulbs
Old Aug 3, 2007 | 12:01 PM
AcuraVibes's Avatar
TeAm InSpIrE
Headlight Bulbs
just wondering if ne body knows how to replace the headlight bulbs on a 2000 acura 3.2 t? or knows a place in the toronto,ontario area... because acura dealership is asking 95 dollars per headlight.
Old Aug 3, 2007 | 12:48 PM
Bob_F's Avatar
Here's a link with some installation tips that I posted:
https://acurazine.com/forums/ramblings-12/two-my-favorite-tv-shows-now-158008/
If you search the forum, there are other posts with more detail.
You'll want D2R bulbs. 4300K is recommended for putting the maximum amount of light on the road.
Does the $95 cost per headlight include the bulb or is that just the labor?
(The bulbs are typically very expensive through a dealer.)
Bob
Old Aug 3, 2007 | 12:59 PM
01tl4tl's Avatar
The dealers charge up to $135 per bulb!!! just for the bulb!!!!!
They are xenon so that makes them expensive- imported from Pluto or somewhere
For replacement Phillips 4300- see ebay- make sure NEW- not used but good- those are dicey
or see vendor Excelerate- he has the badazzz Kaixen brand bulbs- 6000 with color near OE and better output
you really do get what you pay for in lights and brakes~
Old Aug 3, 2007 | 08:45 PM
AcuraVibes's Avatar
TeAm InSpIrE
https://acurazine.com/forums/showthread.php?t=158008
Bob
no its just the labour
Old Aug 3, 2007 | 08:58 PM
Bob_F's Avatar
OK, so you can save a lot of money by doing this yourself. As 01tl4tl mentioned, you can sometimes find great deals on eBay. I bought a pair of brand new Philips D2R bulbs for $68.49 shipped. That's less than $35 a bulb and it will give you a sense of the outrageous markup at the dealerships.
Bob
Old Aug 3, 2007 | 09:19 PM
01tl4tl's Avatar
If you have a few basic tools you can change the bulbs yourself- thats carzy to pay an hour labor to the dealer
And you should replace bulbs in pairs so the light output is even- they change with time
Side note- it takes about 100 hours of use for the color to change and stabilize on new bulbs
Old Aug 3, 2007 | 10:43 PM
JDM96specCTR's Avatar
u need a security torx bit (with the hole in it, t20) and a 10mm
it takes all of 5 mins to change both bulbs. remove the locking screw, unplug the ballast plug, twist the cap, remove bulb. u need the 10mm for the passenger side to take out 1 bolt so u can move hte washer fluid tank neck out of the way
and btw i just bought some 12k bulbs off ebay for about $35
Old Aug 9, 2007 | 07:36 PM
AcuraVibes's Avatar
TeAm InSpIrE
well i got my hands on a torx bit t20 ty everybody for the tip... i will be installing my headlights bulbs tomorrow...hopefully it is easy to install i will tell u guys how it went... thanks again everybody...
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
Mr.Tea
Oct 2, 2015 10:32 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
h22lude
Sep 27, 2015 06:22 PM
