headlight ballast/transformer replacement?
I need to buy this transformer/ballast (not sure which one it is). part no. x6t02991 the port shown connects directly to the low beam bulb, and it is mounted on the underside of the headlight. As you can see this has been majorly corroded and shorted due to the moisture level in the headlight unit itself. I also do need a passengers side headlight unit so if it is necessary to buy that to get the transformer/ballast i will. i also dont want to pay $500 for the part so aftermarket would be great if available. i will be installing myself and would like anyones opinion on how/where to get this cheapest. thanks in advance!
please see the many threads on headlights
many of us are using www.hidextra.com as a good source for full kit with everything you need
Suggest the optional relay kit $16,,only need 1,, to bypass the entire system and prevent problems
the hid kit has 2 new ballast- ignitor/capacitor and bulbs, suggest 5000k bulb color for most useable light on the road ..its usually $59 and has coupons on their own websiite or online search for discount codes for them 10-15% off
its a very simple install - cutting off oe connector and splice the new wires in -
if you can do that, you can do the whole job
ballast can be mounted to outer frame rail (use zip ties) out of the way- and the bulbs wire goes under the housing
the problem is i already tried that but the bulbs you get on hidextra are for brights (if you try to install them there you need no splicing or anything else) and when i did install and turn them on it blew the ballast.
jdub
the hidextra kit comes with D2- bulbs--the correct ones for our HID low beams.
is that what you ordered?,,a low beam kit, or were you intending to upgrade the high beams to HID also?
what exactly did you do?
the new ballast must be spliced into the main power for the lows
it has its own connector wire to the bulb with the capacitor inline on that wire
jdub
it blew a fuse because there is a problem
In your case, it was trying to run 20,000 volts into a 12 volt high beam bulb
HID = High Intensity Discharge
jdubbs11ghost (07-25-2012)
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
0503, 2003, acura, ballast, change, headlight, hid, installation, installing, pounds, replace, tl, transformer, tsx, x6t02991
