Headlight Alignment NOT working
Old Jan 29, 2011 | 06:35 PM
joseph.bruegge's Avatar
I installed new 8000K HIDs in my TL today and when I went to do the aim alignment it would not move the headlight up or down...anyone have any suggestions that would fix this....please let me know thanks in advance
Old Jan 29, 2011 | 06:41 PM
please let me know what i would need to do...thanks
Old Jan 29, 2011 | 10:37 PM
01tl4tl's Avatar
how are you trying to do it? ck the diy section or search
use a + screwdriver -slide down the V track on rear of light housing- see arrow on top of housing -shows which way is up/down
screwdriver tip engages the plastic top gear of adjuster system
may take several turns
if you removed the housings to change bulbs, make sure its back in the same place- look for clean area where the bolts where
did you put the bulbs in the same direction as the old ones came out?
that external wire thing was in same position?
The bulbs seated flat when installed and the wire arm went right in and locked?
any of those can cause align probs
Old Jan 29, 2011 | 10:39 PM
01tl4tl's Avatar
good luck being able to see anything on the road with 8000s
not much white light on the pavement
Old Jan 30, 2011 | 06:48 PM
they are actually pretty good
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
