headlight aiming problem
Old Jun 30, 2010 | 07:50 PM
thewrangler99's Avatar
i was trying to adjust my headlights but i wasn't able to adjust passenger side, it just not go up but it goes down and when i try to move it up it stops at certain point which puts all light output about 6 ft on road whereas driver side works perfect as adjustment goes. please help!
Old Jun 30, 2010 | 08:56 PM
01tl4tl's Avatar
the bolts for the housing are there- car been in an accident?
Old Jun 30, 2010 | 09:00 PM
never been in an accident as far as i know..
Old Jun 30, 2010 | 09:02 PM
i tried your method of aiming headlights, it was way easier but this passenger side gear is moving but not making any difference in height
Old Jul 1, 2010 | 05:48 AM
01tl4tl's Avatar
look if the gears are really turning the final adjuster
Maybe the bulb is in upside down?-- if those were replaced
Old Jul 1, 2010 | 05:50 AM
01tl4tl's Avatar
iirc there is a little bit of play in the bolt holes for the housing- loosen bolts and and move the entire thing up a tick,, see if that fixes it
You may be at the end of the adjustment range? does it stop turning or what?
Old Jul 1, 2010 | 05:42 PM
bulbs were replaced 9 months ago by a local garage mechanic. gear turns along with the bolt.
Old Jul 2, 2010 | 11:09 AM
01tl4tl's Avatar
I suspect the bulb was installed upside down- its easy to do and if you were not paying attention to the external wire when removed--not know which way it goes back in
Also there is a reflector plate that goes over the bulb and attached to one of the tiny screws for the retainer spring arm
If thats missing or fell inside housing--result is light cast onto the ground
DIY or take it back to him
take a close look from outside the lights for any differance in install
Old Jul 2, 2010 | 11:11 AM
01tl4tl's Avatar
the bolt on the middle gear does turn with the adjuster- iirc it holds the gear on~
the adjustment is the method I gave you- from the owner book
TLrascal
Aug 3, 2018 11:00 PM
Sep 17, 2015 10:16 AM
AZuser
Sep 17, 2015 10:15 AM
MistaWet
Sep 15, 2015 08:26 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
