Headlight adjustment question
Old Dec 3, 2008 | 02:04 AM
BlackuraTL's Avatar
Broke college grad
Hey ever since I put my blacked out headlights in which was about a year ago I've noticed my lights point down farther now which annoys me and I brought it into the dealership about a year ago and had them fix it but all they did was raise it about an inch so I just let it go but now its bugging me again. I know which thing you use to change the angle of the lights but I don't know how to do it on my own without takin the whole front apart to get to them again. So if you know an easy trick to get to that golden piece to turn the screw let me know
Old Dec 3, 2008 | 06:31 AM
Rajca's Avatar
wham bam thank you ma'am
theirs a 10mm bolt that u turn. when u pop your hood look in the middle of the head light youll see a 10mm bolt, you turn that to adjust them higher or lower.
Old Dec 3, 2008 | 09:12 AM
harbtheforcaster's Avatar
theres a spot also that you can put a phillips head screwdriver to adjust them so you dont even need a 10mm socket one for left right and one for up and down on each housing its right there when you pop the hood labled right on top of the housing.
Old Dec 3, 2008 | 05:01 PM
BlackuraTL's Avatar
Broke college grad
I know what I have to turn I just can't get to it. I'll take a picture next time I'm home. I'm in college so my car stays at home.
Old Dec 3, 2008 | 07:34 PM
Rajca's Avatar
you could see the bolt in plain sight
Old Dec 4, 2008 | 12:33 PM
ZEUS'O3TL's Avatar
Low & Slow w/Dubz On My
^X2...its next to the HI-beam harness...
Old Dec 4, 2008 | 02:07 PM
BlackuraTL's Avatar
Broke college grad
its probably different on the 02 03 models
Old Dec 4, 2008 | 02:25 PM
Rajca's Avatar
thats how it is on the 02-03 models and the 99-01 shouldnt be any diff.
Old Dec 5, 2008 | 04:19 PM
acutee's Avatar
It is also possible you bent the bulb reflector cap inside the housing while blacking it out causing the beam to go wrong direction. If that was the case, just remove the bulb, and use your finger to bend it back straight.
Old Dec 7, 2008 | 07:00 PM
BlackuraTL's Avatar
Broke college grad
Alright I was home today and I took some pictures I'll upload em later tonight and try to find some pictures from the manual to show you what I am talkin about
Old Dec 7, 2008 | 07:12 PM
Rajca's Avatar
here is the adjustment screw (circled in red)
Old Dec 7, 2008 | 11:41 PM
BlackuraTL's Avatar
Broke college grad
The Gold Piece is under the rubber piece I circled that screws out.
Rubber Piece again
The Golden Piece after the rubber piece is unscrewed that you need to screw which is unreachable for me
What the piece looks like that I'm talking about.
Its hard to get pictures of it. Its one of those things you need to see in person so I don't know if that helped.
Old Dec 9, 2008 | 06:43 PM
BlackuraTL's Avatar
Broke college grad
Anyone?
Old Dec 9, 2008 | 08:38 PM
Rajca's Avatar
look at my pic. thats what your supposed to turn to adjust the headlights
Old Dec 9, 2008 | 08:40 PM
BlackuraTL's Avatar
Broke college grad
I know what I'm supposed to turn! I just can't get to it thats the problem I'm asking about
Old Dec 9, 2008 | 08:42 PM
Rajca's Avatar
how cant u get to what i pictured. i did mine with a 10mm ratcheting wrench
Old Dec 9, 2008 | 11:45 PM
BlackuraTL's Avatar
Broke college grad
Mines different look at the pictures
Old Dec 10, 2008 | 05:13 AM
Rajca's Avatar
maybe bc yours in a 99-01. take off the intake cover (the little flap with the bend in it bay the headlight) and then take a pic.
Old Dec 10, 2008 | 05:22 AM
TequiLa's Avatar
(ಠДಠ)
i messed with that shit when i blacked out my headlights, and my hid cut off's are way off, i gotta fix it up over break.
Old Dec 10, 2008 | 07:51 AM
BlackuraTL's Avatar
Broke college grad
Whatev I look at it closer when I'm home again over break and figure it out I'll let you know
Old Dec 10, 2008 | 02:51 PM
Me0w's Avatar
haha my cutoff looks like your's TequiLa.. i need to do this too.. even my DRLs are way off..
Old Dec 10, 2008 | 03:59 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
wow you aren't blinding anyone with those
tman570
Jun 11, 2019 07:56 AM
BoricuaTL
Apr 8, 2016 01:08 PM
eastcoastguy
Sep 24, 2015 02:07 PM
datadr
Sep 12, 2015 09:12 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
