Half of tailights wont turn on...HELP PLEASE!!!
Old Dec 12, 2014 | 08:35 PM
ecruz206's Avatar
Hi i just recently noticed that my 99 Acura 3.2 TL "brake lamp" light has been coming on although my car brakes just fine and my brake fluid is where it needs to be, the light wont turn off and just recently ONE of my tail/brake lights along with the center brake light (the one that sits up by the rear window) stopped working. So far only one of the brake lights along with the brake light that sits on the spoiler work. I just recently checked the fuses and changed the brake sensor but they still don't work. Any idea as to what could possibly may be going on? Any help or advice will be greatly appreciated. Thanks!
Old Dec 12, 2014 | 08:38 PM
honda_nut's Avatar
2024 Genesis G70 3.3T
Did you try changing the bulbs lol?
Old Dec 12, 2014 | 08:44 PM
ecruz206's Avatar
no but i doubt that it would be the bulbs because they both went off exactly at the same time.
Old Dec 12, 2014 | 11:06 PM
01tl4tl's Avatar
Brake LAMP means exactly that - a brake lamp light has failed
It can be the center one or the regular ones but ALL must work or you get the light
lights burn out in pairs all the time- or very close as they get the same wear~
Of course its possible you have a short but with no blown fuses...not likely
go back and install new bulbs where needed
and the ones that still work- change them out too or be back in there soon!
Old Dec 12, 2014 | 11:07 PM
01tl4tl's Avatar
the brake system warning light says BRAKE in red- you cant miss it!
Old Dec 14, 2014 | 03:50 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Change both brake bulbs, thats the best place to start.
Both rear tail lights use one ground point so I doubt thats the issue.
Old Dec 15, 2014 | 12:27 AM
fsttyms1's Avatar
Like mentioned above. The Brake Lamp warning light means exactly that, you have a bulb out. Start out by replacing the bulbs to see if it corrects the issue.
Old Dec 15, 2014 | 06:51 AM
3.2TLc's Avatar
Brake lamp......
Originally Posted by ecruz206
Hi i just recently noticed that my 99 Acura 3.2 TL "brake lamp" light has been coming on, and just recently ONE of my tail/brake lights along with the center brake light (the one that sits up by the rear window) stopped working.
Yep, as the guys previously suggested. Easy enough to buy new bulbs and try them in the affected tail-lamp and also the hi-mount brake light. If that doesn't work then closely check the bulb's socket receptical for corrosion or a loose wiring connector. You can also check to see if there's power to the socket.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
vpasla1
Sep 17, 2016 07:24 PM
Frathora
Sep 28, 2015 11:29 PM
HOWELLiNC
Sep 18, 2015 11:12 PM
PortlandRL
Sep 14, 2015 12:01 PM
