H.I.D. Problem
Old May 24, 2008 | 12:56 PM
Timon2002TL-S's Avatar
4th Gear
Question H.I.D. Problem
My passenger side light bulb goes from its normal color to purpish orange slowly after turning the headlights on. Then about 5 minutes later turns off totally. If I turn the lights off and then back on, it goes through the same cycle. Is my ballast bad? Can someone help me out?
Old May 24, 2008 | 09:13 PM
'03TL-S's Avatar
Your bulb is probably out. Replace both.
Old May 24, 2008 | 09:49 PM
01tl4tl's Avatar
sounds like bulb death warning
To confirm- swap bulbs side to side
Dealer bulbs are 175 each!!!
Excelerate has Kaixen brand- great replacements in 5000k or 6000k about 150 for a PAIR
always replace in pairs
4300 was stock- see many threads on headlights for more info- there is a diy on the bulbs
Old May 25, 2008 | 12:43 AM
bibledriver's Avatar
Something is missing...my
Out of curiosity does your HL housing have any condensation in it?
Ballasts tend to do weird things when the are going bad so do as 01tl4tl has suggested and you will have your answer (swap bulbs and if it is still pass side, it is a bad ballast. if it is driv side, then bad bulb)
Old May 25, 2008 | 12:54 AM
4th Gear
I replaced the bulb two years ago. As far as I can tell the housing does not have any signs of condensation. I will try the swap first.
Old May 25, 2008 | 01:18 PM
01tl4tl's Avatar
THE bulb? only one side? and its gone out again?
Old May 26, 2008 | 01:28 PM
4th Gear
Yes it went out again. I don't think the bulb I bought was brand new. I swapped out the bulbs yesterday. The bad bulb did the samething on the other side. I looking for a pair on Ebay. Can anyone know the difference between 85126 and 85126+ for GE's part number?
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
