Grinding noise in front end
Old Aug 24, 2007 | 02:31 PM
vinbell's Avatar
Question Grinding noise in front end
Just noticed it today, when I making a left turn or cornering left hard I can hear a light metallic grinding noise coming from the RIGHT front wheel area. The noise is consistent when putting force on the left side of the car, ( I could drive around in a counterclockwise circle and the noise will be constant). Sounds like very light grinding/squealing like metal on metal rubbing. Any ideas?
Old Aug 24, 2007 | 02:43 PM
01tl4tl's Avatar
time to remove the wheels and inspect the brake pads and rotors
If you cant do it yourself take to to a shop-
Sound travels in strange directions too
Old Aug 24, 2007 | 04:32 PM
Mike B's Avatar
If it was the brake heat shield, the sound would be a constant variable. In this case, I do think its a combination of the pad and rotor. However, at the same time, turning angles/direction bears no affect on how the pad/rotor is applied to each other.
Take off the wheel, do an inspection.
TLDude876
Dec 28, 2016 03:18 PM
02tljj
Sep 11, 2015 12:37 PM
08 NBP TL
Sep 8, 2015 08:49 PM
