Getting a bunch of codes.
Old Aug 12, 2016 | 09:30 PM
ImmortalOutlaw's Avatar
3rd Gear
P0131, PO132, P0304, PO305, PO306, P0300, P1399 are the codes i got. I don't inderstand. Spark plugs were replaced with denso, new ignition coils, 3 month old 02 sensors. Cars loses power often and sputters, was getting misfires today, CEL started blinking at stop light with some rough idle. I checked coils while running and it made no difference. I have been using shell v power 91 only. I also cleaned my egr valve. So yeah, any suggestion or help would be great. It also has 230, XXX...
Old Aug 16, 2016 | 01:53 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Remove all 6 coils and inspect for any liquid in the spark plug wells, If there's any liquid in there you need to clear it out. Oil can get in there and cause issues, Also water can do the same thing.
Old Aug 25, 2016 | 07:54 AM
musiclevelz5's Avatar
I recommend NGK Iridium plugs in these engines only. I have had issues when I had Denso in one of my engines.
Also did you buy cheap coil packs? If so you need to get OEM ones. I have bought new cheap coil packs that were bad immediately after installation.
Jbaum
2G RDX Problems & Fixes
Feb 20, 2024 07:27 PM
AcuraOwnr956
Aug 25, 2016 09:31 AM
SuperGreg
Jun 10, 2016 08:02 PM
ton8383
Feb 12, 2016 03:42 PM
mattyacura
Jan 25, 2016 06:00 PM
