Gear indicator
Old Sep 20, 2013 | 01:55 AM
Iggy's Avatar
Gear indicator
Occasionally while driving in D5 the indicator on the dash will go blank then when I wiggle the shift lever the light will come back on. This happens with nuetral as well. I can hear a solenoid clicking when "wiggling" the shifter.
Is my shift cable worn or is there a switch in the center console that is worn?
Old Sep 20, 2013 | 06:43 AM
3.2TLc's Avatar
May need to pull the center console cover and investigate the situation a bit closer. Perhaps a loose connector or something sticking ?
Old Jan 13, 2015 | 12:15 PM
Iggy's Avatar
Turns out it was the transmission range switch that had fallen out of adjustment. Loosen 2 bolts and rotate the housing slightly. Very easy fix.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
AcuraKidd
Sep 26, 2015 04:10 PM
