Garage Transmitter
Old Jul 10, 2007 | 10:30 PM
mrchan625's Avatar
Garage Transmitter
hey guys I need some help here i tried searching but couldnt really find anything and i tried looking at the owners manual for this but it just doesnt work so i need your help.
I want to program the buttons to open the garage door at my house, everytime i do what the owners manual says it doesnt work is there any other way of doing it or am i just doing it wrong?
Old Jul 10, 2007 | 11:58 PM
fsttyms1's Avatar
There are 2 different ways of doing it. Have you tried the 2 ways in the owners manual? If so contact homelink. they will walk you thru it on the phone
Old Jul 11, 2007 | 11:13 PM
grofva's Avatar
I couldn't get mine to program for nothing and finally called Homelink. Even though my original remote was working fine at a distance, the lady @ Homelink suggested I put a new battery in the original remote because the signal probably wasn't strong enough. I didn't believe her but gave it a shot and it worked the first time I tried it.
Old Jul 13, 2007 | 03:21 AM
adamlee05's Avatar
Thread Police Chief
Just a headsup here, its most likely not your Homelink thats the problem.
Most newer garage openers (by that I mean starting around 7 years ago) have the the option to use a standard old-style code, or generate a new code each time the door is opened. Its suppose to help keep people from being able to figure out the pins for your door. Anyhow, our homelink isnt designed to understand the randomized codes, so you cant use it.
But, like I said most of the newers ones that have the randomization feature also have the ability to turn that off, and use the old single-code method. Read your garage door manual and see if you can change it. If so, you should be able to use homelink
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
hpfiend
Sep 27, 2015 06:59 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
