Front motor mount replacement??
Old Oct 20, 2008 | 09:59 PM
Jericho's Avatar
Not Just Low, ULTRA Low
I'm trying to replace my front motor mount on my 2kTLP. I removed the top mount 17mm bolt and the 4 bottom mount bolts. I placed a floor jack under the tranny and when I raise the engine the whole front end rises, the engine bracket doesn't lift off the motor mount at all. As I'm removing the 3 bolts from the engine bracket I can still feel that there is still alot of weight on the motor mount so thats where I stopped. Do I have to remove the side motor mount to raise the engine? Why can't I raise the engine to clear the motor mount?
Old Oct 20, 2008 | 10:10 PM
fsttyms1's Avatar
The motor should raise some with the jack under the motor. If its not your not lifting close enough to the mount. If you remove the 3 bolts that hold the bracket to the motor the mount should slip right out.
Old Oct 23, 2008 | 10:46 AM
acutee's Avatar
You could have left the bottom 4 bolts be loosen last that way when the engine is raised, the mount does not raise along with the engine.
Feb 25, 2020 09:57 AM
drone619
Jan 26, 2016 07:09 PM
wilztlxs
Dec 1, 2015 09:16 AM
RK_AcuraTL
Sep 5, 2015 02:26 AM
asahrts
Sep 4, 2015 05:55 PM
