Front End Vibration
Old Aug 24, 2006 | 07:18 AM
kkisgolfing's Avatar
Front End Vibration
I have a 2001 that has 95K miles. I replaced the stock Michelins with Goodyears about 30K miles ago. Just recently I have been having a front end vibration felt through the steering wheel at different speeds. Typically 55-60, and 75-80.
I ran the Michelins for 60K miles with no problems at all. This is my first time with Goodyear comfortread.
I had the tires balanced and rotated twice. No change in the vibration.
Has anyone had front end mechanical (tie rods, axles, etc.) that have caused this type of vibration? The tire wear is normal, and everthing under the front end seems to be tight, with no cracked boots or rubber grease seals missing on tie rod ends.
Also, has anyone had issues with these tires going bad? I have had a couple of cars that were very tire sensitive and exhibited the same type of vibration.
Old Aug 24, 2006 | 10:50 AM
fsttyms1's Avatar
its possible there is a broken belt in the tire. But if you have rotated and rebalanced the tires and it still happens, i would say its probably something else. You may want to bring it in to a shop and let them inspect teh suspension compononts and halfshafts.
Old Aug 29, 2006 | 08:47 PM
03TYPE-S's Avatar
Michelins are meant for Hondas
I have a honda accord and it has the sme vibration problem.. try askin ur mechanic to road force them
Old Aug 30, 2006 | 02:47 PM
What is road force?
Old Aug 30, 2006 | 11:04 PM
03TYPE-S's Avatar
just ask ur mechanic he SHOULD know if not he aint a mechanic they use drums to simulate ur car ride on a special hoist.. any dealership has it
it diagnoses from bad treads , belt displacements ,alignment , rim bends or problems etc. real effective..
TLDude876
Dec 28, 2016 03:18 PM
02tljj
Sep 11, 2015 12:37 PM
08 NBP TL
Sep 8, 2015 08:49 PM
