Fluids!!!
Old Oct 31, 2012 | 08:34 PM
acuratlforever12's Avatar
6th Gear
Fluids!!!
I thank those of you who have helped me with the other post (the shaking and vibrating issues).
It seems like my '03 TL needs to have new brake fluid and steering fluid. How much do these usually cost to replace??? I just want to get an idea so that I don't end up paying too much...
Old Nov 1, 2012 | 07:04 AM
3.2TLc's Avatar
It's a simple enough job to do, but it all depends where you take it to have the work done.
In my opinion $100 would be a ballpark on replacing the brake and steering fluids. But, most shops will attempt to pad the final bill with other miscellaneous items. They don't like the small 1 hour jobs. Get a couple of estimates from local trustworthy shops.
Old Nov 1, 2012 | 05:16 PM
01tl4tl's Avatar
each job is about 100 at a shop
actual labor time 30 minutes each at a casual pace,,
material= use only!! Honda ps fluid 3pints 30$
Any brand DOT4 spec brake fluid 2 quarts, under $10 total
find small ad in phone book, honda acura listed as specialty
see if you can ask the tech `what is the correct bleed order for a TL?
driver front then clockwise = LF RF RR LR is the only correct answer
if they dont know that they dont touch your new baby!!
thats a different order than most cars
SidhuSaaB
May 30, 2020 12:40 AM
spudweb
May 22, 2016 02:39 PM
LeVeL
Oct 18, 2015 04:19 PM
hpfiend
Sep 27, 2015 06:59 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
