Factory Stereo Removal HELP!
Old Sep 18, 2008 | 09:29 AM
bovaac05's Avatar
My buddy jsut got a 2nd gen TL and his battey died and he doesn't have the code card to put into his stereo. THe dealership said they would give him the code, but they need the stereo's serial number and the only way to get to it is by removing the unit. Does anyone have a DIY on removal of the unit?? I searched and found nothing. HELPP
Old Sep 18, 2008 | 10:15 AM
winhansse's Avatar
http://www.skyeflye.com/acura_cls/In...01-2003_CL.pdf
Try this link, I've done my HD radio w/ this too.
Old Sep 18, 2008 | 07:02 PM
Feelo777's Avatar
The radio code should be on a sticker somewhere in the truck of the car. I just noticed mine there a few days ago.
Old Sep 18, 2008 | 08:46 PM
Bob_F's Avatar
Some cars have stickers while others don't. And they are sometimes in other locations such as the side of the glove box or inside a fuse box.
Old Sep 19, 2008 | 10:00 AM
newperson's Avatar
There's no Acura in
I was lucky....the original owner kept the radio card in the black pouch with the owner's manual.
You can also try to retrieve the radio code here: https://radio-navicode.acura.com/
It says you can retrieve the serial from a sticker in the glove box (ignore the Anti-Theft card):
OR
for '01s and later, you can retrieve it from the display:
  1. Turn the ignition switch to ON.
  2. Turn ON the device and confirm that the display reads COdE. If you don’t see this message, pull the backup fuse for 1 minute, and then go back to step 1.
  3. Turn OFF the device.
  4. Press and hold the 1 and 6 radio preset buttons, and turn ON the device.
  5. The display toggles between two screens: U with the first 4 digits of the serial number (U2200 for example,)
  6. And L with the last 4 digits of the serial number (L0055 for example.)
  7. Ignore the U and L and record all 8 digits
Old Sep 23, 2008 | 12:08 AM
heyitsvu's Avatar
OM NOM NOM NOM
mine is inside the sunglass holder
Old Sep 23, 2008 | 09:36 PM
Bearwolph's Avatar
Any one ever figure out what to do if the code on the ard and the one Acura gives you do not work?
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
STL TL-S
Sep 23, 2015 08:52 PM
