Factory Stereo Removal HELP!
My buddy jsut got a 2nd gen TL and his battey died and he doesn't have the code card to put into his stereo. THe dealership said they would give him the code, but they need the stereo's serial number and the only way to get to it is by removing the unit. Does anyone have a DIY on removal of the unit?? I searched and found nothing. HELPP
There's no Acura in
I was lucky....the original owner kept the radio card in the black pouch with the owner's manual.
You can also try to retrieve the radio code here: https://radio-navicode.acura.com/
It says you can retrieve the serial from a sticker in the glove box (ignore the Anti-Theft card):
OR
for '01s and later, you can retrieve it from the display:
OR
- Turn the ignition switch to ON.
- Turn ON the device and confirm that the display reads COdE. If you don’t see this message, pull the backup fuse for 1 minute, and then go back to step 1.
- Turn OFF the device.
- Press and hold the 1 and 6 radio preset buttons, and turn ON the device.
- The display toggles between two screens: U with the first 4 digits of the serial number (U2200 for example,)
- And L with the last 4 digits of the serial number (L0055 for example.)
- Ignore the U and L and record all 8 digits
navtool.com
31
11-16-2015 08:30 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
STL TL-S
09-23-2015 08:52 PM
