engine runs really rough
Old Apr 17, 2014 | 07:59 PM
adventuredude's Avatar
My 2001 TL began running rough at idle and while revved up shaking .THe car has 140,000 on it and ran pretty well until just recently. What should I try first second third please help we need to be able to drive this car asap
Old Apr 17, 2014 | 08:08 PM
05_NBP_TL's Avatar
HE>i
Spark plugs, coil packs, vacuum leaks, egr valve...
Is the check engine light on?
I had some coil packs go bad and the car would shake under throttle. Replaced the all because I had 120k miles and didnt want to be replacing them one-by-one. Also done the spark plugs while I was in there. Very easy to diy
Old Apr 17, 2014 | 08:10 PM
Skirmich's Avatar
1st = IACV Valve
2nd = MIL Codes (Check Engine Codes)
Old Apr 17, 2014 | 08:19 PM
Dash is lit up like a Christmas tree but that didn't stop it from running great and with the code reader making it thru inspection. Where is the iacv can I just buy that at AutoZone?
Old Apr 17, 2014 | 08:21 PM
Skirmich's Avatar
IACV likes to clog up and needs a good cleaning with TB Cleaner (EASY DIY), No need to buy a new one unless you burn cash...
Old Apr 17, 2014 | 08:34 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Also try this, Just need an allen key and a few minutes.
Old Apr 17, 2014 | 08:48 PM
Okay great I have a couple things 2 try now I can determine which cylinder is bad n maybe buy a coil pack to see if that works where is that valve located I can't find it in the Haynes manual
Old Apr 17, 2014 | 08:50 PM
And what is tb cleaner
Old Apr 17, 2014 | 08:52 PM
Skirmich's Avatar
Throttle Body Cleaner? = comes as a Spraying Can in Autozone..
Seems to me your not very used to moving stuff in the engine, should leave it to a mechanic unless you wanna start your DIY career..
Old Apr 17, 2014 | 09:02 PM
Funding may be the cause of my current diy career the car has actually run great I have the bad transfer code but no symptoms did the 3x3 so far so good never touched the engine except oil changes
Old Apr 17, 2014 | 09:04 PM
Bad transmission code
Old Apr 17, 2014 | 09:06 PM
Skirmich's Avatar
Then cleaning the IACV should be a walk in the park.. Dunno if you have seen the DIYs but its pretty straight forward; Remove intake tubes > Remove Throttle Body > Remove IACV just by the 2 Philips screws > Clean it and Vualá!! You got your RPMs in check again.
Old Apr 18, 2014 | 07:17 AM
Okay did the coil pack test idle goes down on all cylinders ect one so auto zone is right down the street going to buy a coil pack also when I took the engine cover off there is oil in each pouch of the top of motor does that indicate anything? Thanks so much for help so far
Old Apr 18, 2014 | 07:41 AM
Nicks2001tl's Avatar
Post the code numbers. That could take out the guess work.
Old Apr 18, 2014 | 07:50 AM
Middle rear coil pack replaced got rid of the shake and roughness now I'm motivated to change the transmission filter or anything else to save this transmission you guys rock
Old Apr 18, 2014 | 07:52 AM
Took the what you Guys called the engine cover at auto zone and can't figure out what that gasket is called please help the very top cover with like 8 bolts
Old Apr 18, 2014 | 08:08 AM
The gasket generally doesn`t need to get replaced. Just make sure you put it back the right way.
The top cover of the engine if it is caked with carbon deposits you can bet the EGR valve, IACV valve and the throttle body is the same way.
If so brake cleaner for the EGR valve and ports. TB cleaner for the TB and IACV valve.
Also 1 can of seafoam in the gas tank when it is almost empty.
Old Apr 18, 2014 | 09:45 AM
3.2TLc's Avatar
Arrow Basic cleaning of motor parts......
First, have the CEL codes read. Then, clean things like the EGR passageways, TB intake, and IAC valve. Check out the 2nd Gen's "DIY" sticky for tips and details on procedures. Clear codes and see if they come back.
Post the codes and we can better help ya.
mada51589
Jan 9, 2025 04:40 PM
01CLOwner
Oct 9, 2015 01:07 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
PortlandRL
Sep 14, 2015 12:01 PM
kuzdu
Sep 10, 2015 08:42 PM
