ENGINE GURU's- HELp
Old Apr 10, 2006 | 11:26 PM
illTL's Avatar
ENGINE GURU's- HELp
Hi,
ok here is the problem, my 2000 acuta tl3.2..does not pick up as it always has, foer some reason when i press the gas just a little, it picks up normal, but as soon as i give it a lil more gas, the engine starts to shake a little, and keep doing that till i press the gas all the way down..it does not sound good at all..
does anyone have an idea of what is going on? i took it a shop and they said it might be a misfire in the engine someone, but i wanted to ask ppl on here first..
thanks
alot
ro
Old Apr 10, 2006 | 11:35 PM
Blazin_TL's Avatar
Registered User
sounds like a misfire, im having sort of the same problem. have you ever changed your coils or plugs? might want to check that
Old Apr 11, 2006 | 12:14 AM
illTL's Avatar
i am going to look 2morrow about it
is it common>?
Old Apr 11, 2006 | 12:21 AM
Blazin_TL's Avatar
Registered User
well it depends on your mileage...
Old Apr 11, 2006 | 07:54 AM
NSXNEXT's Avatar
I had the same problem. Is the check engine light on?
Here's my thread from it. Turns out one of my coil packs was bad. It's an easy fix that you can easily do yourself.
https://acurazine.com/forums/showthread.php?t=168147
Old Apr 12, 2006 | 12:29 PM
illTL's Avatar
thank you, i am going to do the same thing next week sometime for sure...
so im going to take it to a buddy's shop who has a ODB11 scanner, and see what we get..and then order a coil pack.
i hope to GOD it fixes it.
lol, but i just wanted to say thank you soo much for the help guys and ill keep you guys posted.
ro
Old Apr 12, 2006 | 01:19 PM
NSXNEXT's Avatar
ro
Good luck. Hopefully it's something cheap.
SidhuSaaB
May 30, 2020 12:40 AM
spoiler900
Oct 10, 2015 06:48 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
